TwinTurbo.NET: Nissan 300ZX forum - Re: Re: Help, Rebuild, or Buy a used block?Blown motor
Subject Re: Re: Help, Rebuild, or Buy a used block?Blown motor
Posted by txq45 on January 31, 2011 at 5:04 PM
  This message has been viewed 105 times.
In Reply To Re: Help, Rebuild, or Buy a used block?Blown motor posted by Krazyd27 on January 31, 2011 at 03:33 PM
Message Depends on HOW much you would have to bore it out to get a smooth cylinder wall.. If .020 or less you can use your existing block ,, if more you might get a stock block and build it. The cost would most likely be the same since you would have to acquire another block..
Nistune Dealer
Email glennmccall8@gmail.com
ECU socketing ECU eprom upgrade
