TwinTurbo.NET: Nissan 300ZX forum - Re:what are you using to measure boost? if the stock..
Subject Re:what are you using to measure boost? if the stock..
Posted by tognot on January 31, 2011 at 1:22 AM
  This message has been viewed 495 times.
In Reply To 300zx low boost issue posted by Jiro on January 30, 2011 at 12:28 PM
Message gauge is what you have start there. 2nd, spend $5.00 and wire a resistor in place of your det. sensor if you doubt it. done a simple resistance test on your det. sensor?
The auto turbos arent your problem. Also, dont apply more than 4 or 5 psi when boost leak testing and you wont blow seals. good luck!
