TwinTurbo.NET: Nissan 300ZX forum - Re: Either replace lower plenum or helicoil the stripped holes..
Subject Re: Either replace lower plenum or helicoil the stripped holes..
Posted by jaidieray on January 30, 2011 at 10:09 PM
  This message has been viewed 202 times.
In Reply To Either replace lower plenum or helicoil the stripped holes.. posted by KongZTT GT28RS MD on January 30, 2011 at 01:35 PM
Message Definitely use a heli-coil. IIRC the kit you need is 8MM X 1.25 pitch but you can take the bolt to the hardware store and verify to make sure. Ive never heard of using blue loctite on a heli-coil and i've installed plenty of them at work on aircraft engines but to each his own. Good luck and be sure to vacuum all the chips up from the drilling and tapping.
90na2tt swap kh2 charcoal 5spd
93tt 5spd crp=sold 90na auto gold=sold
06 spec v=sold 95 awd talon=sold
