TwinTurbo.NET: Nissan 300ZX forum - This really is relatively easy to troubleshoot and it
Subject This really is relatively easy to troubleshoot and it
Posted by jzack on January 29, 2011 at 4:00 PM
  This message has been viewed 119 times.
In Reply To Dont think its the alternator,I just replaced it. posted by Serg300zx on January 29, 2011 at 02:48 PM
Message still could be the alty (if a rebuilt and not totally new). You'll need a meter to run the tests but if the battery's current draw is high enough, might be able do it with a small low wattage (12v) incandescent test lamp instead?
Battery's negative terminal is disconnected and test lamp (or meter) is placed between clamp and battery terminal. If lamp is glowing - it means a high current flow. Pull fusible links until lamp goes out and report back on which link did the trick.
