TwinTurbo.NET: Nissan 300ZX forum - Could be a couple of things
Subject Could be a couple of things
Posted by Stadsport (PHX) on January 28, 2011 at 9:29 PM
  This message has been viewed 91 times.
In Reply To Oil pressure sending unit failure method posted by KasbeKZ(VA) on January 28, 2011 at 07:26 PM
Message The OPSU might have indeed failed or become clogged (the opening is pretty small and it clogs pretty easily. It could also have a loose/dirty harness connection, or the o-ring on the oil tree could have failed.. when it goes you usually just see lower oil pressure through the sensor; the oil pressure isn't actually down, but less oil is being forced through the filter+sensor, which obviously isn't great either.
It could also be the gauge; our clusters kind of suck.
