TwinTurbo.NET: Nissan 300ZX forum - true... the name is misleading...
Subject true... the name is misleading...
Posted by TeddyZ(SFC) on January 27, 2011 at 12:54 PM
  This message has been viewed 144 times.
In Reply To Easy-outs aren't always that easy. posted by Shiers69 on January 27, 2011 at 12:25 PM
Message There have been many a time where the easy-out was anything but easy... however, a wise man once showed be a couple of tricks...
1. after inserting the easy outs, tap the back of it with a hammer as you turn it. this also works for those stubborn screws that wont turn.
2. thread penetration fluid (not WD40-i can't remember the name), let it soak and try step 1.
3. after drilling the hole for the easy out, get a blow torch and heat up the broken screw a bit. Then proceed with step 1 if it's not budging...
