TwinTurbo.NET: Nissan 300ZX forum - ^This. Install a proper high current capable plug
Subject ^This. Install a proper high current capable plug
Posted by CoHPhasor on January 26, 2011 at 5:47 PM
  This message has been viewed 73 times.
In Reply To Your probably overheating it. posted by michaell32 on January 25, 2011 at 12:28 AM
Also, don't use a CRT, try to use something with a low draw.
I believe even plasma is heavy on draw, so take a look around.
The ideal situation is to find a set that is actually 12V so you can just use a regular car adapter instead of an inverter.
ps, the 300z's have a notoriously terrible charging system, you might considered an upgraded alternator if you're going to screw with this.
(There were a few in the classies this last month)
