TwinTurbo.NET: Nissan 300ZX forum - Check the fusible links.
Subject Check the fusible links.
Posted by CoHPhasor on January 25, 2011 at 10:37 PM
  This message has been viewed 125 times.
In Reply To Re: yes, if your plugs are fouled it wont start. if they are posted by tognot on January 25, 2011 at 12:39 AM
Message I'm sure that an instantaneous grounding during operation was not good for your electrical system.
IF your car needed the bypass for fuel, then you went lean for that moment, but if it was not in boost you should be ok.
Fusible links make things go wonky, what can I say.
It's likely the security system is disabling startup.
