TwinTurbo.NET: Nissan 300ZX forum - Re: It will hold ~ 35 psi at idle, and it is boost referenced
Subject Re: It will hold ~ 35 psi at idle, and it is boost referenced
Posted by -Grimm- on January 25, 2011 at 4:05 PM
  This message has been viewed 124 times.
In Reply To It will hold ~ 35 psi at idle, and it is boost referenced posted by ZiNnYc on January 25, 2011 at 06:38 AM
Message Yeah meant damper and regulator.
I was planning on running it with the single input from the fuel pump, stock return from the regulator, and two outputs from the regulator to each side of the fuel rails.
My only concern with this setup is that the fuel will not be recirculating as much as stock, and might cause heat related issues with the fuel?
Ill check it out, thanks.
