TwinTurbo.NET: Nissan 300ZX forum - Double check the math?
Subject Double check the math?
Posted by SeanK (StL) on January 24, 2011 at 12:17 PM
  This message has been viewed 98 times.
In Reply To Injector duty cycle calculations... posted by Mr. Magoo on January 23, 2011 at 05:37 PM
Message >"I read the ecu chip and used the programmed map values for the calculations.
>MAF voltage of 4v @ 5638 rpm = ~94% duty cycle
>(as reported by NDS)"
Can you elaborate? Did you look at the fuel tables and get the data or did you do a dyno/highway pull to get the data?
In NDS duty cycle is calculated not read. Make sure something is not messing up that calculation. Use the formulas from the id10.html page and compare to the injector pulsewidth read @ RPM. Those duty #'s would seem more plausible for 370cc injectors, not 555cc's.
