TwinTurbo.NET: Nissan 300ZX forum - Is it running roughly? powerbalance test?
Subject Is it running roughly? powerbalance test?
Posted by CoHPhasor on January 24, 2011 at 1:09 AM
  This message has been viewed 106 times.
In Reply To Injector duty cycle calculations... posted by Mr. Magoo on January 23, 2011 at 05:37 PM
If a cylinder isn't firing then the unburnt air will tell the O2's you're running lean and the ECU will try to adjust for it and ask the injectors to give more than they can.
Can I ask,... why you think you should go up to6+ grand when you're instruments are telling you you're very lean and or asking for more than injectors can give?
