TwinTurbo.NET: Nissan 300ZX forum - coolant leaking into engine
Subject coolant leaking into engine
Posted by evil300zx on January 18, 2011 at 8:21 PM
  This message has been viewed 143 times.
Message This is my first post, unfortunately a bad one. I have coolant leaking into my engine. This summer I was at someone's house and found a ton of coolant on the ground under my car. I took my car home coolant leaked onto floor even after I turned the car off. Since I parked my car it has not leaked out of the engine since. Before the leak I had my coolant system flushed. I recently checked oil and it keeps getting higher, and under the cap there is a milky slime. I checked the compression ratio and all the cylinders were reading about 155 psi. When it was leaking out of the car the coolant was coming from the front of the engine and appeared to be coming from the passenger side of the car. I was wondering if you guys had any ideas on what it could be.
