TwinTurbo.NET: Nissan 300ZX forum - I tried 3 seperate resistors (2 1mega ohm resistors 1/2
Subject I tried 3 seperate resistors (2 1mega ohm resistors 1/2
Posted by scooter4zx on January 18, 2011 at 6:41 PM
  This message has been viewed 112 times.
In Reply To Re: thanks for the input doomday but thats where i had it wired posted by DoomDay300 on January 18, 2011 at 05:19 PM
Message watt. and I also tried 1 mega ohm 1 watt.same outcome.reseting the ecu with battery disconnected for at least 1/2 hour each time.just took the car for another ride and still showing 34.any other thoughts.I know the connections are good with solder and I also ohmed each resistor out with my multimeter.Then i checked continuity between ground and ecu harness pin 23.Not that this means alot but I am an electrician by trade so I should know a good connection.Any other thoughts.
