TwinTurbo.NET: Nissan 300ZX forum - Re: woody how is it possible i'm throwing 34 with the resistor
Subject Re: woody how is it possible i'm throwing 34 with the resistor
Posted by DoomDay300 on January 17, 2011 at 11:58 PM
  This message has been viewed 137 times.
In Reply To woody how is it possible i'm throwing 34 with the resistor posted by scooter4zx on January 17, 2011 at 11:07 PM
Message Wire in the resistor in at the ecu connector. I believe its pin 23? Might want to double check. cut the wire, solder one end of the 1 mega ohm resister to the wire leading to the ecu, and ground the other end of the resister. It could be that the wires running from the ecu to the knock sensor under the hood could have a break in the circuit. If you do this, i recommend that you run some type of knock detector (maybe a knock light). The last thing you want is a hole in your piston ;) Hope this helps.
