TwinTurbo.NET: Nissan 300ZX forum - disconnected and removed. (n/m)
scooter4zx
on January 17, 2011 at 5:24 PM
Are your stock boost solenoids discod since you have a BC? (n/m)
posted by Woody75 (Denver)
on January 17, 2011 at 09:33 AM
code 34 det. sensor problem
scooter4zx
18:03:50 01/15/11
Re: code 34 det. sensor problem (n/m)
njz
19:54:08 01/15/11
Recheck your work, (n/m)
njz
19:57:32 01/15/11
Check for swapped connectors
DE944
00:12:32 01/16/11
The connectors are connected correctly
scooter4zx
09:39:06 01/16/11
Just in case you need a new one.
jschrauwen
09:56:41 01/16/11
thanks (n/m)
scooter4zx
10:38:18 01/16/11
now i'm completly confused.
scooter4zx
12:19:27 01/16/11
Could something else throw a 34 code? (n/m)
scooter4zx
13:04:55 01/16/11
I know you said it already, but you're SURE of the connector
CoHPhasor
14:07:24 01/16/11
the vtc connector has a white sheath on it with black and
scooter4zx
14:56:51 01/16/11
I just cleared the ecu again and reversed the vtc and
scooter4zx
15:27:19 01/16/11
allittle change here
scooter4zx
18:34:16 01/16/11
Woody75 (Denver)
09:33:36 01/17/11
disconnected and removed. (n/m) -
scooter4zx
17:24:02 01/17/11
Then safety boost is no longer an option. (n/m)
Woody75 (Denver)
19:43:53 01/17/11
woody how is it possible i'm throwing 34 with the resistor
scooter4zx
23:07:40 01/17/11
Re: woody how is it possible i'm throwing 34 with the resistor
DoomDay300
23:58:36 01/17/11
thanks for the input doomday but thats where i had it wired
scooter4zx
16:33:52 01/18/11
Re: thanks for the input doomday but thats where i had it wired
DoomDay300
17:19:39 01/18/11
I tried 3 seperate resistors (2 1mega ohm resistors 1/2
scooter4zx
18:41:46 01/18/11
Re: I tried 3 seperate resistors (2 1mega ohm resistors 1/2
DoomDay300
23:47:51 01/18/11
Just changed both 02 sensors to narrow things down and no
scooter4zx
16:30:10 01/20/11
Re
DoomDay300
01:19:24 01/21/11
