TwinTurbo.NET: Nissan 300ZX forum - Re: 2nd
Re: 2nd
black&yellowttz
on January 16, 2011 at 8:53 PM
2nd
posted by jschrauwen
on January 16, 2011 at 02:10 PM
the only problem using only distilled water will cause is rust in the cooling passages and possibly not enough lubricant for the waterpump straight water cools better than antifreeze
Need Help!! Still Overheating
texasfan1528(CA)
22:23:54 01/15/11
Have you replaced your radiator cap? (n/m)
Stadsport (PHX)
23:35:49 01/15/11
Time to do a compression test
DE944
00:16:04 01/16/11
The first sign of a blown head gasket is combustion gases
zellamay
01:11:45 01/16/11
Coolant pressure test and CO test should reveal >>>
ZUL8TR
07:14:24 01/16/11
Are you purging the system of air
jschrauwen
09:52:12 01/16/11
answers
texasfan1528(CA)
11:25:18 01/16/11
You didn't mention about selecting the heater on and
jschrauwen
14:05:06 01/16/11
Update
texasfan1528(CA)
12:50:23 01/16/11
Maybe you were using too much water
fcz32
13:28:09 01/16/11
2nd
jschrauwen
14:10:12 01/16/11
Re: 2nd -
black&yellowttz
20:53:12 01/16/11
ok so maybe water has a higher
fcz32
03:01:12 01/17/11
Re: ok so maybe water has a higher
black&yellowttz
10:16:59 01/17/11
You are correct. 100% water will transfer heat better
zellamay
14:46:13 01/17/11
Distilled = demineralized. Just don't use Deionized. (n/m)
marklar182
17:58:47 01/17/11
Keep the anti freeze at no greter than about 50%. (n/m)
ZUL8TR
08:25:01 01/17/11
Update 2
texasfan1528(CA)
19:55:03 01/17/11
Re: Update 2
lurker_nz
17:25:45 01/18/11
Note that gravity draining the coolant system will >>
ZUL8TR
08:41:51 01/19/11
