Better describe rattle sound? Is idle erratic? Describe the poor performance you are having? Have you checked for codes? Look into MAS connector and mas sensor. Look into coolant temp sensor connector and sensor spec. Is your POP Charger free of leaks at connections? Consider a compression and leak down test. Have you done the timing belt service?
