TwinTurbo.NET: Nissan 300ZX forum - Time to do a compression test
DE944
on January 16, 2011 at 12:16 AM
Need Help!! Still Overheating
posted by texasfan1528(CA)
on January 15, 2011 at 10:23 PM
Sounds like a probable head gasket or leaking turbo. If you cant do a compression test then start with a cooling system pressure test and go from there.
texasfan1528(CA)
22:23:54 01/15/11
Have you replaced your radiator cap? (n/m)
Stadsport (PHX)
23:35:49 01/15/11
Time to do a compression test -
DE944
00:16:04 01/16/11
The first sign of a blown head gasket is combustion gases
zellamay
01:11:45 01/16/11
Coolant pressure test and CO test should reveal >>>
ZUL8TR
07:14:24 01/16/11
Are you purging the system of air
jschrauwen
09:52:12 01/16/11
answers
texasfan1528(CA)
11:25:18 01/16/11
You didn't mention about selecting the heater on and
jschrauwen
14:05:06 01/16/11
Update
texasfan1528(CA)
12:50:23 01/16/11
Maybe you were using too much water
fcz32
13:28:09 01/16/11
2nd
jschrauwen
14:10:12 01/16/11
Re: 2nd
black&yellowttz
20:53:12 01/16/11
ok so maybe water has a higher
fcz32
03:01:12 01/17/11
Re: ok so maybe water has a higher
black&yellowttz
10:16:59 01/17/11
You are correct. 100% water will transfer heat better
zellamay
14:46:13 01/17/11
Distilled = demineralized. Just don't use Deionized. (n/m)
marklar182
17:58:47 01/17/11
Keep the anti freeze at no greter than about 50%. (n/m)
ZUL8TR
08:25:01 01/17/11
Update 2
texasfan1528(CA)
19:55:03 01/17/11
Re: Update 2
lurker_nz
17:25:45 01/18/11
Note that gravity draining the coolant system will >>
ZUL8TR
08:41:51 01/19/11
