| Message |
So when you did this, what causes it to idle at 1000-1200 rpm? Does the AAC take over and just raise the idle until it's warmed up? (that makes the air regulator just seem redundant) Also, in the writeup you linked, it talks about an adjustment on the Air Regulator, did you try that before deleting it?
