| Drill a small hole in one of the two sheets of metal.. use the MIG with a gun "circular" motion to fill the hole that you drilled. Start in the center of the hole drilled (MIG wire should be in touching bottom layer of metal/center of hole).. Do a quick swirl ( I would use a little higher heat setting than what you'd usually use on whatever thickness since its a quick burst). Viola! spot weld. Ps. Use a clamp or vise grips or somthing to keep them tightly together before welding. When buying a welder.. get a good one to start off with (within your needs).. and dont get the harbor freight welder etc.. I just got a Hobart 140 (same as Miller, few small differences).. and its 110v. So I can use it anywhere and is plenty powerful for things I do for around my Z.
_________________________________________________________________________ ~~~ Sig starts below ~~~ =================================================================NO, This picture is not photoshopped.
AIM:Shawn300zxTT "-Any closeups on the nuts? - zboost(tx) 19:17:53 08/08/05 -Not really something you want to ask another man about... (n/m) - LordZ 19:24:00 08/08/05" "I just took 45 min and scrubbed the heck out of my rear" teambushido(San Diego, CA) 19:24:51 12/11/04 -1991 Stage _ TT 5spd (Upgraded to hell and back) -1990 Super White 2+2 Na Stage 3 Auto (Deceased :( ) -1990 Cherry Red Pearl ,Auto Coupe (Parts car) -1990 11 Sec Eagle Talon Tsi AWD, (SOLD!) -2001 Ford F-150 Crew cab, 5.4 Triton v8.. Tow bitch -1997 Acura 2.2 CL, 5spd. Daily Driver.. great little car! -2004 Honda CBR 600RR (Candy blue, FOR SALE) |
