TwinTurbo.NET: Nissan 300ZX forum - I forgot.. the Coolant temp sensor as well.. (bigger clip)
Subject I forgot.. the Coolant temp sensor as well.. (bigger clip)
Posted by KongZTT GT28RS MD on January 14, 2011 at 2:18 AM
  This message has been viewed 99 times.
In Reply To Ok Got timing Set at 15 degrees but getting rough idle posted by blkrocket on January 14, 2011 at 12:22 AM
Message on outlet water pipe.
clean electrical connection (bigger one sends signal to ECU, smaller sends to gauge in cluster)
You can also take the sensor out.. ( I believe 17mm wrench).. use some ~800 grit sand paper and "twist sand" the element that sees the coolant path. Reinstall.
Test your 02 sensors.
The coolant temp and 02s have different effects on motor once its warmed up.
Very easy to check.. so I would start with battery connections, then all electrical connections.. then go from there.
use the FSM
_________________________________________________________________________
~~~ Sig starts below ~~~
MySpace for those who have em'
AIM:Shawn300zxTT
-1997 Acura 2.2 CL, 5spd. Daily Driver.. great little car!
