TwinTurbo.NET: Nissan 300ZX forum - The fog lights are no longer connected to the high side of
Subject The fog lights are no longer connected to the high side of
Posted by 300NASeattle on January 12, 2011 at 2:04 PM
  This message has been viewed 346 times.
In Reply To Re: Strange Fog light behavior after HID Install posted by RobZ32 on January 12, 2011 at 01:18 PM
Message headlight low beam (I assume just the left) relay but it is still grounded through the dimmer relay. I will have to think on it to understand it. I will do some testing as well - disconnecting head lamps etc. to determine if I can reverse condition.
In the end, I can intercept the wire coming from the fog light switch and ground it directly. Then the fog lights will stay on even when you use the high beams.
