| To OP: If they stick you have a bad sensor. Saturated with fuel, clogged and not ventilating, or damaged in som other way. I tracked and tracked performance problems fo a long tme and it turned out to be O2s. How many miles are on these O2s? They are a part that goes bad over time, especially after running under bad conditions for a while. Even a short while. If these are the same O2s that came with the car originally or if they are not OEM, replace them and then come back.
___________________ "If everybody is thinking alike, somebody isn't thinking." ~~ George S. Patton Blow money on your Z. This is a Z forum isn't it? |
