TwinTurbo.NET: Nissan 300ZX forum - All brake fluids EXCEPT DOT 5 are compatible.
Subject All brake fluids EXCEPT DOT 5 are compatible.
Posted by Under_Powered on January 10, 2011 at 8:27 PM
  This message has been viewed 155 times.
In Reply To Completley changing brake fluid posted by d_flore on January 09, 2011 at 04:18 PM
Message DOT 3, DOT 4, DOT 5.1 are ok to "mix." The only problem you will encounter is if you try mixing DOT 5, which is silicone-based, with any of the above. It will react and turn to foam.
The trace amounts of DOT 3 left in your system after a thorough flush/bleeding with whatever you are switching to (I'm assuming DOT 4) will be negligable and you shouldn't notice any negative side-effects.
If you're really concerned about it though, you could go the extra mile and flush the entire system with denatured alcohol to eliminate any traces of the old fluid...
Wide open until you see God, then brake.
