TwinTurbo.NET: Nissan 300ZX forum - Re:your theroy regarding velocity affecting o2 is not valid.
Subject Re:your theroy regarding velocity affecting o2 is not valid.
Posted by tognot on January 09, 2011 at 9:38 PM
  This message has been viewed 104 times.
In Reply To Re: Your O2's aren't moving much. Is it warmed up? posted by preprodigy on January 08, 2011 at 03:12 PM
Message but it is interesting. what did your o2 reading do when you introduced propane as suggested?
rather than do that you would pull the O2 's and install new ones?
I also commented the injectors can be bad although they "test " good.
Use a logical approach, ruling things out one at a time. replacing parts without a reason gets frustrating and expensive. good luck.
