TwinTurbo.NET: Nissan 300ZX forum - Thanks for the info.
Subject Thanks for the info.
Posted by Wright (Ca) on January 09, 2011 at 7:11 PM
  This message has been viewed 912 times.
In Reply To Throttle Body Setting and Synchronizing posted by jschrauwen on January 09, 2011 at 10:58 AM
Message Unfortunately my Z1 tb's seem to let too much air to pass no matter how well adjusted they are. I set up mine up almost exactly as you have described here but can't get my Z to idle under 1100 rpms.
No boost/vacuum leaks. When the tb's are at their maximum closed position they still let too much air to pass. I have gotten the Z to idle lower by adjusting them to close even more but then they get stuck shut after any quick blip of the throttle.
I believe it is a quality issue that varies between each set as I know there are plenty out there without this issue.
I have decided to live with the high idle for now but next time I have the engine out or plenum off I am going to experiment with a file and see if I can't get the valves to close more with out sticking.
Formerly: ZEVAN (Ca), Evan3zx(ca)
