TwinTurbo.NET: Nissan 300ZX forum - The back pressure shouldn't be affecting the O2's.
Subject The back pressure shouldn't be affecting the O2's.
Posted by CoHPhasor on January 08, 2011 at 4:53 PM
  This message has been viewed 97 times.
In Reply To Re: Your O2's aren't moving much. Is it warmed up? posted by preprodigy on January 08, 2011 at 03:12 PM
Message The O2's are right after the manifold, so it should move enough to be measured.
Following what the others have ointed out about O2 readings off-idle, I notice that your RH O2 is still hovering at the mid-point.
The RH O2 does move towards .7V, but honestly it takes a while.
Either the bank is running strangely (less likely) or your RH O2 might be getting old.
It is possible your injectors on that side might be having a problem, one not giving enough fuel.
Post what the resistance measurement is on them.
I hate to blindly replace parts, but it might be worth your wile to switch out that PS O2.
The PS is the easy one if you have an O2 socket.
ps, O2's cause bad performance if they aren't running properly.
