TwinTurbo.NET: Nissan 300ZX forum - Try bleeding the system. Jack the front of the car up
Subject Try bleeding the system. Jack the front of the car up
Posted by doug8867 on January 06, 2011 at 9:04 AM
  This message has been viewed 171 times.
In Reply To Re: Re: Your fluid is low. Make sure to use ATF Type III posted by Caveman on January 06, 2011 at 08:13 AM
Message Start the car, remove the resevoir top then get in the car and turn the wheels side to side several times.
I know you don't feel it is leaking, but your symptoms sure seem to indicate a fluid problem. Have you gotten under the car and looked for signs of leakage? The alternator is usually wet on top when it's leaking. The ATF is a reddish color.
I have previously experienced the cold weather light on before, and the intermittent nature of your problem, and it's always been due to low fluid. My reason is due to an annoying small leak near the pump in my case.
