TwinTurbo.NET: Nissan 300ZX forum - Could be as simple as a large vacuum leak. Check
Subject Could be as simple as a large vacuum leak. Check
Posted by doug8867 on January 06, 2011 at 7:44 AM
  This message has been viewed 81 times.
In Reply To Loss of power, rough idle posted by Seyr on January 04, 2011 at 08:54 PM
Message that the intake hoses are securely fastened on the underside of the connection points. Some times they can get squished up there and not form a tight connection.
Look in tt.net classifieds and buy a boost leak checker, it's under $20 and can help you find not only boost leaks (since you have an NA you won't have any of those :-) but air leaks in general. Good luck.
