TwinTurbo.NET: Nissan 300ZX forum - Pictures don't work, but here's a description
Subject Pictures don't work, but here's a description
Posted by BigTDogg (MA) on January 04, 2011 at 1:45 PM
  This message has been viewed 138 times.
In Reply To Re: I'd remove the baffles, clean the sand blasting media out posted by akdawgg99 on January 04, 2011 at 10:18 AM
Message From a post years ago:
"So, Aliaz tells me to go to the grocery store, and buy some stainless steel pot scrubbers. I’m like, “sure I guess he wants me to chip in and do the dishes or something”. Being the good little helper I am I run over to albertson’s and pick up these. Then he tells me, OK, now we are going to put them in your engine. I was thinking WTF!?!?
Sure enough…
The PCV pipes have been relocated to the top of the intake valve covers where they are much less likely to have oil slosh up into them. This is good, but there is still an air/oil mist up in there that can float out. The SS scrubbing pad acts as a screen that the oil mist will collect on instead of floating out the top of the valve cover.
It fits under the baffle like so. WARNING: If you get your valve covers powder coated you should at least remove your baffles and clean under them before reinstalling them on the car. The powder coating and bead blasting media gets stuck up under there and WILL damage your motor."
"...Downpipes own. They own everything...anything...all there ever was and will be...they should be stock on all
cars. Screw the environment, emissions, noise! I love them...I shall name my first-born after them with glee..." -
SeedyRom 05:13:20 10/03/02
