TwinTurbo.NET: Nissan 300ZX forum - Re: Is it hard to replace an NA water pump and thermostat?
Subject Re: Is it hard to replace an NA water pump and thermostat?
Posted by Marty1Mc on January 04, 2011 at 12:24 PM
  This message has been viewed 135 times.
In Reply To Is it hard to replace an NA water pump and thermostat? posted by Havoc300 (Chicago) on January 04, 2011 at 11:56 AM
Message :Coolant leak around bottom center of motor after the engine is turned off. No leak while engine is running, and the heat is not getting that hot anymore. I replaced the radiator after it had a crack at the inlet neck.
No, it's not hard to do. It can be time consuming. Just take your time, follow the FSM instructions.
Here is a link:
[ http://www.300zx.co.uk/cgi-bin/manual.cgi?list=lc&dir=&config=&refresh=&slide=10&cycle=off&scale=0&design=default&total=15 ]
