Coolant leak around bottom center of motor after the engine is turned off. No leak while engine is running, and the heat is not getting that hot anymore. I replaced the radiator after it had a crack at the inlet neck.
Is it hard to replace an NA water pump and thermostat? - Havoc300 (Chicago)11:56:49 01/04/11
