TwinTurbo.NET: Nissan 300ZX forum - 2nd on the soft valves.
Subject 2nd on the soft valves.
Posted by Draker (Eugene, OR) on August 09, 2010 at 3:00 PM
  This message has been viewed 191 times.
In Reply To IACV is a common area for leaks posted by ZiNnYc on August 09, 2010 at 06:47 AM
Message This was a 1996 JDM clip. I don't think it's got soft valves.
I've checked all the hoses in the area, I'm starting to think it's not a boost leak. It could be a vacuum leak not showing up under the boost test.
I've checked the CP part numbers and all are the same. I've got a second set from my original engine, as well as plugs. I'll swap all those over while I wait for new plugs to get here.
I will start going down the list of electrical items and testing them. Thanks for the input once again. The idle is off just enough to drive you insane.
