There are plenty of connections that could be funked out after 2 yrs.Check the majors and work your way down. CAS, PTU, Coils, Injectors, Battery, etc. Green/White is bad. 2 yrs? I don't know what tells you the fuel pump is fine, but that Fuel Filter needs a once-over. We also don't know much about what you've done. Honestly? You told us you had no boost so you replaced the turbos,.... at this point you may have replaced them for no reason because you didn't know any better. Give us something to work with ;-)
