TwinTurbo.NET: Nissan 300ZX forum - Sounds like your expansion valve is stuck
ILoveBoost
on July 16, 2010 at 2:15 PM
Need advice on course of action. AC related.
posted by Wright (Ca)
on July 15, 2010 at 07:45 PM
I would replace the expansion valve and convert it to R134a. You can get an inexpensive one from NAPA.
Wright (Ca)
19:45:28 07/15/10
the expansion valve could be stuck, oriface tube clogged
JustinSCZ32
20:10:15 07/15/10
Re: Need advice on course of action. AC related.
clulesssss
20:56:03 07/15/10
What are the running pressures?
Draker (Eugene, OR)
00:56:11 07/16/10
I believe those were the running pressures but it's been
Wright (Ca)
09:04:14 07/16/10
Thoes are bad numbers for sure.
Draker (Eugene, OR)
17:38:18 07/16/10
Sounds like your expansion valve is stuck -
ILoveBoost
14:15:02 07/16/10
Marty1Mc
06:52:31 07/17/10
After running the ac for a while the low pressure pipe in
Wright (Ca)
13:01:00 07/17/10
You said you can see the clutch engage, right?
JustinSCZ32
14:27:49 07/17/10
Yep, clutch definitely engages and stays. (n/m)
Wright (Ca)
15:24:15 07/17/10
Re: Yep, clutch definitely engages and stays.
clulesssss
19:10:55 07/17/10
Yep R12 only.
Wright (Ca)
03:29:37 07/18/10
Re: Yep R12 only.
clulesssss
09:49:37 07/18/10
I actually live in woodland which is way north of woodland
Wright (Ca)
10:15:06 07/18/10
Re: Re: Yep, clutch definitely engages and stays. (n/m)
clulesssss
09:51:31 07/18/10
