TwinTurbo.NET: Nissan 300ZX forum - The stock tension rods had OEM deflectors.
Subject The stock tension rods had OEM deflectors.
Posted by ZiNnYc on May 25, 2010 at 10:43 AM
  This message has been viewed 184 times.
In Reply To Re: StopTech, based on application specific balanced setups posted by mskdallas on May 24, 2010 at 09:37 PM
Message SPL also offers a nicer deflector that bolts onto their adjustable tension rods. StopTech has designs built into their AeroRotors and the caliper itself that allow for great cooling. A larger surface area rotor will help as well. If you want to go all out, some custom ducting can be routed through foglight ducts/fascia, but honestly I believe that a superior brake setup and the deflectors will change your experience tremendously without going the route of external ducting.
Did you have drilled rotors?
