TwinTurbo.NET: Nissan 300ZX forum - Re: HID fog light install - no power to the fogs
Subject Re: HID fog light install - no power to the fogs
Posted by vigman on May 23, 2010 at 3:02 PM
  This message has been viewed 407 times.
In Reply To HID fog light install - no power to the fogs posted by Invader on May 22, 2010 at 11:23 PM
Message Headlights have to be ON ( or at least marker/ running lights have to be on ) this gets power to the Fog lamp switch.. If that has power THEN there is a diode block the control line passes through and pulls in the fog lamp relay you should hear the relay go click click when you push the button... There is a 15 amp fuse supplying power for the fog lights in the under hood relay/ fuse box....
Mike
