TwinTurbo.NET: Nissan 300ZX forum - Climate control pod doesn't control heat/ac (or light up)
Subject Climate control pod doesn't control heat/ac (or light up)
Posted by SPeedyZman on May 21, 2010 at 12:03 PM
  This message has been viewed 476 times.
Message Hey guys, I have a 91 Z32 TT & am having Climate Control pod issues.
The heating system was only blowing hot air thru the system regardless of what it was set on. (figured a bad servo, bad brain, or chewed wires)
After changing the black box (brain on the drivers side of the heater box) the pod no longer lights up or controls anything with the heat/ac system.
It doesn't even light up anymore but still controls the rear wiper.
I tried changing to 3 different brains from several different z32s as well as 3 or 4 different climate control pods and none would light up.
All fuses were checked & I'm good there.
I'm not sure what else it could be so I'm open to suggestions.
I just yanked the dash in frustration, as its not that bad to do, and may just replace the whole heating box...... but i'd rather not if I don't have to. (and that may not resolve the issue of the pod not lighting up)
I tried searching, but search wasn't working presently....
any advice is appreciated.....
Thanks guys!
Damon
