TwinTurbo.NET: Nissan 300ZX forum - Re: Re: Fuel Gauge Problem
Subject Re: Re: Fuel Gauge Problem
Posted by gbhrps on May 20, 2010 at 9:30 PM
  This message has been viewed 1226 times.
In Reply To Re: Fuel Gauge Problem posted by nismo_tuned on May 18, 2010 at 07:49 PM
Message You have 2 sending units. One has the sending unit and fuel pump as an assembly. The other has the fuel sending unit and the low fuel light assembly. The dash gauge averages the two. Pull the sending units out of the tank and hook them up to a multimeter to read ohms (resistance). Across the pins of the connector a two seater's units should read from 8-11 ohms when full (float at top) and 157-170 ohms when the float is at empty.
If you get these readings, you either have a bad ground, a broken or corroded wire somewhere to the front of the car, or a bad fuel gauge in the dash. Good Luck!
