TwinTurbo.NET: Nissan 300ZX forum - Re: replacing lower plenum
Subject Re: replacing lower plenum
Posted by I_LB_VAJ on May 20, 2010 at 5:58 PM
  This message has been viewed 128 times.
In Reply To replacing lower plenum posted by starscream714 on May 20, 2010 at 01:48 PM
Message Timing belt has to be loosened off, and the stud from the lower plenum removed that holds the one idler wheel. I double nutted my stud than turned it out. Its a C U Next Tuesday of a job.
ALso, tech tip of the day, zip tie your timing belt to your cam gears in 2 spots each, than you don't have to worry about your timing being out so long as no tension is lost between the crank timing gear and the cams. I ran out of zip ties and used vice grips with a rag between the jaws and my belt. DOn't need alot of tension just enough to hold it to the gears.
