TwinTurbo.NET: Nissan 300ZX forum - Best way to remove spring/ball valve on block?
Subject Best way to remove spring/ball valve on block?
Posted by rome06 on May 19, 2010 at 10:15 AM
  This message has been viewed 99 times.
Message The spring was tore up and stretched out so i removed the ball bearing and the spring that surrounds it and going to plug up the holes. I cant seem to remove the remaining seal in the block. The metal is very soft and breaks as soon as you put any pressure on it. Is there a trick to removing these things?
