TwinTurbo.NET: Nissan 300ZX forum - MC problems
Subject MC problems
Posted by KasbeKZ(VA) on May 17, 2010 at 5:55 PM
  This message has been viewed 101 times.
Message MC sat empty for a few months, now i'm having a bit of a problem. i'm wondering if there are more mechanisms in it than i can tell from my bit of dis-assembly.
when a problem became apparent, i took it out and took the primary plunger out, inspected, reassembled. now i'm doing a bit of experimenting on the bench with getting it bled (i don't have the necessary hook ups to do a proper bench bleed until tomorrow, so i was just letting it squirt strait out for experimental purposes), and i found that only the opening for the rear hose was squirting. that is, the hole in the front of the cylinder.
i thought back and realized that i was getting MUCH less volume out of the front lines when doing the standard bleed. what should i do here? a new master is definitely a possibility, but this one is only 2 years old, so i'd like to fix it if possible. if a replacement is recommended, where is good. advanced auto is my usual parts store.
