TwinTurbo.NET: Nissan 300ZX forum - Re: Re: Dry solder joint......
Subject Re: Re: Dry solder joint......
Posted by Marty1Mc on May 16, 2010 at 7:23 AM
  This message has been viewed 105 times.
In Reply To Re: Dry solder joint...... posted by DNic (WA) on May 13, 2010 at 09:40 PM
Message Also, check your speed sensor on the transmission. Easy to do without getting under the car. Take it out for a drive and see if the cruise control works. If it does, the speed sensor is not the problem and you need to look at the speedometer. If it doesn't, then look at the speed sensor as it isn't feeding pulses. Check the connector on the sensor as they get pretty nasty and dirty...
