TwinTurbo.NET: Nissan 300ZX forum - Re: Punctuation?
Subject Re: Punctuation?
Posted by Marty1Mc on May 16, 2010 at 7:00 AM
  This message has been viewed 79 times.
In Reply To Punctuation? (n/m) posted by Draker (Eugene, OR) on May 15, 2010 at 01:02 AM
Message OK, as stated before the NA power steering hard line will interfere with the pipes moving into the proper location. You can work around this, but it ain't pretty. Basically, you need to slide the PS tube toward the firewall about an inch. You also need the TT AC lines. The high pressure line can work, but the low pressure line (the fat one) is different.
Next, look at the thread on 3ZC. I found it to be the best reference for how the thing bolts up. The first shot is Ash's pic for how they work. Scroll down and you can see the IC piping and how it bolts to the radiator supports. This is the only bolt you really need to use to hold in the piping. The two pipes bolt to each other at the end and the combination will hold them pretty firm.
[ http://300zxclub.com/showthread.php?t=102345&highlight=intercooler+piping ]
