TwinTurbo.NET: Nissan 300ZX forum - Plenum removal help
Subject Plenum removal help
Posted by BryceZ on May 15, 2010 at 3:06 PM
  This message has been viewed 263 times.
Message I'm working on removing the plenum following NytWolf's guide, but I'm a little confused on step 14:
"14. Unclamp and remove the crankcase ventilation hose/pipe assembly that runs from the IAA unit on the rear of the plenum to the turbo compressor hard pipe"
What exactly do I need to remove?
The big hoses at the rear of the plenum (the right on the picture) are attached to pieces that seem bolted to the plenum. Do I have to remove all of the hoses and unbolt the pieces they are attached to? Is there an easy way to remove the whole assembly at once?
