TwinTurbo.NET: Nissan 300ZX forum - Re: With a code 34 -det sensor- is the car safe to drive?
Stadsport (PHX)
on May 14, 2010 at 3:01 PM
posted by Initial Z
on May 14, 2010 at 02:53 PM
It is, but your ECU won't be able to detect detonation, so it
would be wise not to drive it hard. It's super easy to do, you just
take out the old plenum bolt and pick up one that's about an inch
longer from Ace. There are plenty of writeups for it.
Initial Z
14:53:24 05/14/10
Re: With a code 34 -det sensor- is the car safe to drive? -
Stadsport (PHX)
15:01:12 05/14/10
Pretty sure it's an M6x1.0 bolt, about 15-20mm long (n/m)
16:25:31 05/14/10
Re: Re: With a code 34 -det sensor- is the car safe to drive?
aliaZ
19:07:04 05/14/10
it isnt turbo..... (n/m)
Initial Z
21:50:17 05/14/10
oops. I thought you bought a TT (n/m)
aliaZ
23:23:08 05/14/10
Not yet, and this is slowing down the process lol....
Initial Z
02:58:08 05/15/10
I cleaned the sensor and now i come up with a code 55 lol...
Initial Z
16:50:07 05/14/10
now im getting a code 34 again.....
Initial Z
13:45:31 05/15/10
Curious, how did you manage to clean the sensor? At the very
Wright (Ca)
13:15:16 05/16/10
sorry was just the connector at the top, by the balance tube (n/m)
Initial Z
15:26:33 05/16/10
before you take anything apart...
surfer31337
03:01:27 05/16/10
No it runs fine when it actually starts....
Initial Z
03:32:46 05/16/10
Actually, I take that back, I am misfiring....
Initial Z
00:31:01 05/17/10
Code 34 has nothing to do with weather or not the car is
Wright (Ca)
13:10:00 05/16/10
replacing the efi harness should fix it right? lol
Initial Z
15:27:41 05/16/10
You most likely need a new det sub harness. Also you
Wright (Ca)
17:46:26 05/16/10
Any idea why the codes flux between 34 and 55....
Initial Z
20:41:11 05/16/10
Your ecu codes were cleared when your battery died. After
Wright (Ca)
22:03:01 05/16/10
well, its still fluxing and its a brand new battery :) (n/m)
Initial Z
00:27:23 05/17/10
that makes no sense to me
surfer31337
19:07:23 05/16/10
Take a look at your fsm. The det sensor does detect
Wright (Ca)
20:24:13 05/16/10
got it now, thanx (n/m)
surfer31337
04:23:15 05/17/10
