TwinTurbo.NET: Nissan 300ZX forum - Diagnosing Idle Issues - PCV Rattle
Subject Diagnosing Idle Issues - PCV Rattle
Posted by MixManMash on May 13, 2010 at 10:12 PM
  This message has been viewed 378 times.
Message So, in my latest quest to diagnose idle issues (I have tried everything - boost leak testing, changing MAFs, ECUs, switching back to recircs from BOVs, on and on), I recently replaced the O2 sensors with 2 known good ones. The car still doesn't idle well (really low when cold, and almost wants to stall). Again, if I leave them off when cold, the car idles fine.
Once warm, it does idle somewhat ok, with and without the O2s plugged in. Now, here is where it gets weird. The RPMs vary a little bit. It will sit a little low for 20 seconds around 600-650ish, but then go back up to about 750-800 RPM and hover there for another 20 seconds and then repeat. During this transition, I can hear the PCV valves rattling.
Could it be that my idle issues are related to PCV valves going bad?
