TwinTurbo.NET: Nissan 300ZX forum - Re: Speedometer Issue
Subject Re: Speedometer Issue
Posted by Pkawbzx on May 13, 2010 at 4:55 PM
  This message has been viewed 89 times.
In Reply To Speedometer Issue posted by DNic (WA) on May 13, 2010 at 03:10 PM
Message I had a similar issue and had to take my gauge cluster apart to fix it. After I got the face off (the black part), I sprayed some lubricant on the dial mecanism that rolls all the numbers (not the numbers themselves, but everything behind them). I think it was the trip reset button/rod that was messing mine up. The spring attached to it was pretty crusty and was not letting it function properly. Be careful not to spray too much if you try this because any excess gets all over everything when you try to put it back together.
