TwinTurbo.NET: Nissan 300ZX forum - In the Z32 positive displacement pump system it is >>>
Subject In the Z32 positive displacement pump system it is >>>
Posted by ZUL8TR on May 13, 2010 at 4:46 PM
  This message has been viewed 78 times.
In Reply To Oil pressure question. posted by ZiNnYc on May 13, 2010 at 08:15 AM
Message gear driven with the engine and at a given engine rpm the pump has a specific rpm. Any restriction in the supply line would reduce the flow rate in the system and increase the line pressure. Any line pressure that exceeds the relief valves pressure would be blown off and excess oil is returned to the oil pan. So removing any restrictions would lower oil pressure regardless of where the restriction is.
ZUL8TR in Orlando,FL
