TwinTurbo.NET: Nissan 300ZX forum - BTW Air in the line has nothing to do .................
Subject BTW Air in the line has nothing to do .................
Posted by Greg D. (Specialty-Z) on May 12, 2010 at 8:37 PM
  This message has been viewed 154 times.
In Reply To Only 1 correct way to get the max adjustment and still allow posted by Greg D. (Specialty-Z) on May 12, 2010 at 08:30 PM
Message Air in the line has nothing to do with pedal height change from temperature....
Air can only make the pedal less than firm, but the pedal will still be consistent.
A incorrectly adjusted pedal will cause the pedal height to change with temperature and is almost always the cause.
A weak pressure plate diaphragm can also cause the pedal to change with heat.
